How to reset register to specific value?
Handpick0800
Joined Apr 25, 2024
Hello, I've been asked to create a countdown that starts from 9 and counts down to 0.
but, I'm struggling with setting the register value to a specific number. Whenever I need to reset the register, it defaults to 0.
Below is my circuit:
Thank you.
Handpick0800
Joined Apr 25, 2024
Hi E,
I have no idea, I've just been asked to use Cedar Logic Simulation to create a counter from 9 to 0 and 5 to 0, along with a reset button, using registers and logic gates.
I'm just not sure how I'm supposed to set the register value to another, like jumping from 1 to 9 when pressing the reset button.
ericgibbs
Joined Jan 29, 2010
21,554
Hi H,
I don't use the Cedar simulator.
You can see on the left side of the counter IC drawing there are 4 pin lines, these are used to set the output of the counter from a number from '0' to' 9'.
The other pins along the top are usually a parallel load pin which is used to load the count value on the left pins into the counter.
Just using the Reset pin line will default the count to '0'.
E
35,093
Your generic counter has four inputs. Set these input pins to the BCD value that you want to preset.
I would assume that the L input means LOAD. Try sending a high pulse into L to load the register.
Make sure that the R input (assuming that this is RESET) is set to the inactive state. Don't leave it not connected.
