I have a remote control with 3 buttons: open, close, and stop (the remote controls drapes). I am trying to convert it to the lazy persons remote, in that instead of needing buttons pressed, it will sense light or dark and move the drapes accordingly without human interaction.
I have created several separate versions of light/dark detectors that work on their own. But I can't figure out how to combine those functions with the remote. I have also tried replacing the LED tester in my circuits with IR lights, before I learned remotes have IR codes.
I have removed the open/close buttons on the remote (stop is useless in my desired outcome), and soldered wires to the leads. The remote still works if I short the leads.
I have attached some pictures. The first is the remote as it currently is.
The top 2 wires (white) go to the close function. The bottom 2 wires (gray) go to the open function. The other 2 pictures are 2 different versions of light/dark detectors.
They are currently set up with LEDs as the output.
In the end, I would like the drapes to close when it's dark, and open when it's light.
Sorry in advance for any errors or stupidity, this is my first circuit project in many years. Also, a little warning: I really struggle at reading circuit diagrams. So please bear with me if it's more than something extremely basic.
