For either pin 10 or 11 one is Q, and the other is Q with a bar above it.
If I wanted to post about the bar one, what do I call it ?
Also, the pins 4 & 5, I think, cause 10 and 11 to do something.
The data sheet says a high level on one or a low level on the other.
What is the level in reference to ? Is it usually spelled out in the data sheet ? Is it ground ?
Also how do I refer to what is happening at pins 10 and 11 ?
Emitting, pulsing, broadcasting ?
