How to read this diagram?
ScottWang
Joined Aug 23, 2012
7,501
You can see above kindly advise the following
No. 1 and 2 Resistor R3 51K between where is the no.1 and 2 connected to?
Please see my attached circuit.
3. SHDN - where is it connected to?
Please see my second attached circuit.
4. R1/117 K - is this a fixed resistor or variable i am just confused why R1/117 K instead of just R1 117K
That is a fixed resistor, please see my attached circuit.
Unless you want a precisely resistor then you can using a 100K+VR20K, otherwise you can using a 120 K to replace 117K. (120K-117=3K, Pcnt_R1 = 3K/117K=2.56%)
5. L1/6.8uH - Is this inductor just 6.8uH?
Yes.
LM2371 Datasheet.
ScottWang
Joined Aug 23, 2012
7,501
Perfect answer..tqvm but just curious question why the SHDN got arrow out what does it really meant?
It means that you can using SHDN pin to control the leds to be flashing as the second circuit, and set SHDN = High(1.5V) then the SHDN is in the flash enable situation, the leds will be flashing, set SHDN = Low(0V or gnd) and then the SHDN is in the flash disable situation, the leds can work in flashing function, if you don't want the SHDN function then you can connect it to Vin pin(5V).
SHDN - shutdown, you can check the datasheet to see more information about SHDN.
I don't have the ic in hand, so I can't try it, if you have this ic then you can try it.
12,158
SHDN is a control signal input to the chip. With R3 installed, you can leave it floating and the chip will operate all the time. If you want to shut down the boost circuit electronically, pull the SHDN input to ground. The arrow indicates that that connection goes off to some other switch or circuit that generates the shutdown signal.
The basic problem here is that the schematic in post #1 is very poor. It looks like someone copied a datasheet circuit, but
1. their software did not make some of the connections; that's why some lines step around some component pins.
2. the way they show reference designation and component value is inconsistent. R3 is done the right way, refdes and value on two separate lines, no confusion. The wrong way is the way R1 is done. A dash would be slightly better than a /, but both are confusing.
