How to pull-down low voltage in L298N H-bridge?
fablau
Joined May 14, 2020
167
Hello everyone.
I am an electronic newbie, and I am replacing an L293D H-bridge IC with an L298N in a circuit controlled by an Arduino UNO driving two bidirectional coils, due to higher currents needs, but for some reason, I am unable to have a zero (or almost zero) voltage when the L298N H-bridge should be off (when all inputs and enable pins are set to LOW). I always get around 450mV from the outputs.
Here is the schematics of the circuit I am working on:
I have tried to add a 10k pull-down resistor at the inputs (5,6,7) and enable (10,11,12) pins, but no avail. Any tips to avoid having that pretty high voltage at the outputs when the H-bridge should be off?
Here is the datasheet of the L298N for reference:
https://www.mouser.com/datasheet/2/389/cd00000240-1795236.pdf
Any suggestions and thoughts are very welcome!
All the best,
Fab.
sghioto
Joined Dec 31, 2017
8,750
The only thing I see missing on the schematic is a 100nf cap on pin 9.
Something doesn't look right where is the 5 volts for the Vss supply coming from?
Alec_t
Joined Sep 17, 2013
15,156
Have you tried monitoring the input pins of the L298 with a scope, to check there are no spurious oscillations?
fablau
Joined May 14, 2020
167
Just had a thought, if using different supply sources, are the commons bonded at a star point GND?
Max.
Yes, both the Arduino and the supply source have common grounds (if that's what you are asking). Later today I am going to try a different L298N chip, maybe the one I was using is defective in some way?
fablau
Joined May 14, 2020
167
I just didn't see any 5 volt supply shown. What are the actual readings on the output pins when OFF?
Good question: if I remove the 5v logic supply, the readings are still up to around 450mV. It looks coming from the 32v supply!
CORRECTION: In my first post above, I wrote that I read around 200mV on the output pins when in standby, whereas it is actually 450mV when the supply is at 32v! Sorry for the typo, I'll edit my post right away. I also replaced the schematics with the correct capacitor No.3.
fablau
Joined May 14, 2020
167
I 'll rephrase, what are the voltage readings on the output pins?
So sorry, for some reason I wrote mA instead than mV. Corrected!
And here is my definitive answer to your question: When the 5v logic supply is off, I still read 450mV. Something's wrong!
Also, please note, that when I take the readings, there's no load connected (the coils in the schematic above are NOT connected). I just read the output directly with the multimeter alone.
fablau
Joined May 14, 2020
167
Of course, guys, thank you so much for bearing with me... I am such a newbie! Connected the load, measured and it is back to zero. Appreciated you help and sorry again for the whole mess ;)
All the best,
Fab.
