I do like thisWhat does a line like this mean?
#define RSL P0^0 = 0
If it's "Set bit 0 of Port 0 low" then it's a format that I've never seen.
#include <mcs51reg.h>
#define LcdDataBus P2
#define LcdControlBus P0
#define DefaultDigits 10
#define GlcdFirstLine 0x00u
#define GlcdLastLine 0x07u
#define FirstLineAddress 0xB8
#define LastLineAddress 0xBF
#define BUSY_FLAG 7
void DELAY_us(int x);
void DELAY_ms(int x);
void GLCD_Init(void);
void GLCD_DisplayChar(unsigned char ch);
void GLCD_DisplayString(unsigned char *);
void GLCD_ScrollMessage(unsigned char lineNum, char *strptr);
void GLCD_Clear(void);
void GLCD_GoToPage(unsigned char );
void GLCD_GoToLine(unsigned char );
void GLCD_GoToNextLine(void);
void GLCD_SetCursor(unsigned char lineNumber,unsigned char CursorPosition);
void glcd_SelectPage0();
void glcd_SelectPage1();
void glcd_BusyCheck();
void glcd_CmdWrite( unsigned char cmd);
void glcd_DataWrite( unsigned char dat);
int GLCDPageNum;
int GLCDLineNum;
int GLCDCursorPos;
#define FONT_SIZE 5
const char GlcdFontTable[]=
0x00, 0x00, 0x00, 0x00, 0x00, // space
0x00, 0x00, 0x2f, 0x00, 0x00, // !
0x00, 0x07, 0x00, 0x07, 0x00, // "
0x14, 0x7f, 0x14, 0x7f, 0x14, // #
0x24, 0x2a, 0x7f, 0x2a, 0x12, // $
0x23, 0x13, 0x08, 0x64, 0x62, // %
0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x05, 0x03, 0x00, 0x00, // '
0x00, 0x1c, 0x22, 0x41, 0x00, // (
0x00, 0x41, 0x22, 0x1c, 0x00, // )
0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x00, 0xA0, 0x60, 0x00, // ,
0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x60, 0x60, 0x00, 0x00, // .
0x20, 0x10, 0x08, 0x04, 0x02, // /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x00, 0x42, 0x7F, 0x40, 0x00, // 1
0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x21, 0x41, 0x45, 0x4B, 0x31, // 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x3C, 0x4A, 0x49, 0x49, 0x30, // 6
0x01, 0x71, 0x09, 0x05, 0x03, // 7
0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x06, 0x49, 0x49, 0x29, 0x1E, // 9
0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x08, 0x14, 0x22, 0x41, 0x00, // <
0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x41, 0x22, 0x14, 0x08, // >
0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x32, 0x49, 0x59, 0x51, 0x3E, // @
0x7C, 0x12, 0x11, 0x12, 0x7C, // A
0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x7F, 0x41, 0x41, 0x22, 0x1C, // D
0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x3E, 0x41, 0x49, 0x49, 0x7A, // G
0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x20, 0x40, 0x41, 0x3F, 0x01, // J
0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x7F, 0x04, 0x08, 0x10, 0x7F, // N
0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x3E, 0x41, 0x51, 0x21, 0x5E, // Q
0x7F, 0x09, 0x19, 0x29, 0x46, // R
0x46, 0x49, 0x49, 0x49, 0x31, // S
0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x3F, 0x40, 0x38, 0x40, 0x3F, // W
0x63, 0x14, 0x08, 0x14, 0x63, // X
0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x7F, 0x41, 0x41, 0x00, // [
0x55, 0xAA, 0x55, 0xAA, 0x55, // Backslash (Checker pattern)
0x00, 0x41, 0x41, 0x7F, 0x00, // ]
0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x03, 0x05, 0x00, 0x00, // `
0x20, 0x54, 0x54, 0x54, 0x78, // a
0x7F, 0x48, 0x44, 0x44, 0x38, // b
0x38, 0x44, 0x44, 0x44, 0x20, // c
0x38, 0x44, 0x44, 0x48, 0x7F, // d
0x38, 0x54, 0x54, 0x54, 0x18, // e
0x08, 0x7E, 0x09, 0x01, 0x02, // f
0x18, 0xA4, 0xA4, 0xA4, 0x7C, // g
0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x40, 0x80, 0x84, 0x7D, 0x00, // j
0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x7C, 0x04, 0x18, 0x04, 0x78, // m
0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x38, 0x44, 0x44, 0x44, 0x38, // o
0xFC, 0x24, 0x24, 0x24, 0x18, // p
0x18, 0x24, 0x24, 0x18, 0xFC, // q
0x7C, 0x08, 0x04, 0x04, 0x08, // r
0x48, 0x54, 0x54, 0x54, 0x20, // s
0x04, 0x3F, 0x44, 0x40, 0x20, // t
0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x44, 0x28, 0x10, 0x28, 0x44, // x
0x1C, 0xA0, 0xA0, 0xA0, 0x7C, // y
0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x10, 0x7C, 0x82, 0x00, // {
0x00, 0x00, 0xFF, 0x00, 0x00, // |
0x00, 0x82, 0x7C, 0x10, 0x00, // }
0x00, 0x06, 0x09, 0x09, 0x06 // ~ (Degrees)
x>>=3;
while(x--);
while(x--)
DELAY_us(1000);
void GLCD_Init()
/* Select the Page0/Page1 and Enable the GLCD */
glcd_SelectPage0();
glcd_CmdWrite(0x3f);
glcd_SelectPage1();
DELAY_ms(10);
glcd_SelectPage0();
glcd_CmdWrite(0xc0);
glcd_SelectPage1();
GLCD_GoToPage(0);
/* Clear the complete LCD during init */
GLCD_Clear();
/* Set the cursor to beginning of page0 */
GLCDPageNum=0;
GLCDLineNum=0xB8;
GLCDCursorPos=0x40;
GLCD_GoToPage(0);
unsigned char dat,i=0;
int addr = 0;
if(((GLCDPageNum == 0x01) && ((GLCDCursorPos+FONT_SIZE)>=128)) || (ch=='\n'))
/* If the cursor has reached to end of line on page1
OR NewLine command is issued Then Move the cursor to next line */
GLCD_GoToNextLine();
if(ch!='\n') /* TODO */
ch -= 0x20; // As the lookup table starts from Space(0x20)
addr = ch * 5;
while(1)
if((GLCDPageNum == 0x00) && (GLCDCursorPos==0x80))
/* If the cursor has reached to end of line on page0
Then Move the cursor to Page1 */
GLCD_GoToPage(1);
dat= GlcdFontTable[addr+i]; /* Get the data to be displayed for LookUptable*/
i++;
glcd_DataWrite(dat); /* Display the data and keep track of cursor */
GLCDCursorPos++;
if(i==FONT_SIZE) /* Exit the loop if End of char is encountered */
glcd_DataWrite(0x00); /* Display the data and keep track of cursor */
GLCDCursorPos++;
break;
void GLCD_DisplayString(unsigned char *ptr)
while(*ptr)
GLCD_DisplayChar(*ptr++);
unsigned char i,j,k,l,cursor,ch;
if(lineNum > 7)
lineNum = 0; // Select first line if the var_lineNumber_u8 is out of range
for(i=0;strptr[i];i++)
/* Loop to display the complete string, each time 16 chars are displayed and
pointer is incremented to point to next char */
for(k=0;k<6;k++)
GLCD_SetCursor(lineNum,6-k); //Move the Cursor to first line
cursor = 6-k;
for(j=0;strptr[i+j] && (cursor<128);j++)
ch = strptr[i+j]-0x20;
for(l=0;(l<5) && (cursor<128);l++)//Display first 16 Chars or till Null char is reached
glcd_DataWrite(GlcdFontTable[ch+l]);
cursor++;
if(cursor==64) /* Has the cursor reached end of page0 */
glcd_SelectPage1(); /* then set it to beginning of page1 */
glcd_CmdWrite(FirstLineAddress+lineNum);
glcd_CmdWrite(0x40);
glcd_DataWrite(0);
cursor++;
while(cursor < 128)
DELAY_us(10);
cursor++;
DELAY_ms(20);
void GLCD_Clear()
unsigned char line,cursor;
for(line=0;line<8;line++) /* loop through all the 8lines to clear the display */
glcd_SelectPage0(); /* Select page0 and set the cursor to first position */
glcd_CmdWrite(FirstLineAddress+line);
for(cursor=0;cursor<128;cursor++) /* Clear all the 128 pixels of selected line */
glcd_DataWrite(0x00); /* Clear each pixel by displaying blank */
GLCD_GoToLine(0);
void GLCD_GoToPage(unsigned char pageNumber)
if((pageNumber==0) || (pageNumber ==1))
{ /* for 128/64 GLCD only page 0&1 are supported.
Select the specified page and move the cursor accordingly */
if(pageNumber == 0)
glcd_SelectPage0();
else
glcd_SelectPage1();
GLCDPageNum=pageNumber;
GLCDCursorPos=0x40;
glcd_CmdWrite(GLCDLineNum);
glcd_CmdWrite(GLCDCursorPos);
void GLCD_GoToLine(unsigned char lineNumber)
if(lineNumber<8)
{ /* If the line number is within range
then move it to specified line on page0 and keep track*/
GLCDLineNum = lineNumber+FirstLineAddress;
GLCD_GoToPage(0);
void GLCD_GoToNextLine()
/*Increment the current line number.
In case it exceeds the limit, rool it back to first line */
GLCDLineNum++;
if(GLCDLineNum > LastLineAddress)
GLCDLineNum = FirstLineAddress;
GLCD_GoToPage(0); /* Finally move it to next line on page0 */
unsigned char pageNumber;
if(((lineNumber >=0x00) && (lineNumber <= GlcdLastLine))
&& ((CursorPosition>=0x00) && (CursorPosition <= 128)) )
pageNumber = CursorPosition / 64; //Divide the cursor pos by 64 to get the page
CursorPosition = CursorPosition % 0x3f; // Cusror pos should be within 64(0x3f),
if(pageNumber==0x00) /* Check for page number and set accordingly */
glcd_SelectPage0();
else
glcd_SelectPage1();
GLCDPageNum = pageNumber; /* Keep the track of page selected */
GLCDLineNum=lineNumber | FirstLineAddress; /* Select the specified line number */
GLCDCursorPos=CursorPosition |0x40; /* Select the specified cursor position */
glcd_CmdWrite(GLCDCursorPos); /* Command the LCD to move to specified page,line,cursor*/
glcd_BusyCheck();
LcdDataBus = cmd ;
P0^0 = 0; // Select the Data Register by pulling RS LOW
P0^1 = 0; // Select the Write operation by pulling RW LOW
P0^2 = 0; // Send a High-to-Low Pulse at Enable Pin
DELAY_us(1);
P0^2 = 1;
void glcd_DataWrite(unsigned char dat)
glcd_BusyCheck();
LcdDataBus = dat;
P0^0 = 1; // Select the Data Register by pulling RS LOW
DELAY_us(1);
P0^2 = 1;
P0^3 = 1;
P0^4 = 0;
P0^3 = 0;
P0^4 = 1;
DELAY_us(100);
void main(void)
GLCD_Init();
GLCD_Clear();
GLCD_DisplayString("Hello world!!!");
while(1);
They use this format in GNU compiler chains... To use sfr or sbit on SDCC is a bit of a phaff so I do it this way..If it's "Set bit 0 of Port 0 low" then it's a format that I've never seen.
I think I have to spend more time with Keil. I tried your two solution but It doesn't workThey use this format in GNU compiler chains... To use sfr or sbit on SDCC is a bit of a phaff so I do it this way..
#define RSL ( P0^0 = 0 ) // this just does what I've done above... It is more portable..
