Beginner question. Looking to make sure I don’t fry something. Setup. 12v AC feeding a gate keypad. When the code is entered 12v AC is fed to an electronic latch. NC latch so only remains open for as long as there is power. To make it smart I planned on paralleling 12v AC to the latch from a smart dry contact. Fearful that the 12v applied at the latch will cause damage to the keypad.
I know you use a diode on a dc circuit to prevent back feeding voltage from the latch to the keypad. Can’t recall if you can use a diode on both wires of AC to accomplish the same.
thanks in advance.
thanks in advance.
