Dear all ,
Current is been injected into Human body through pair of outer (Ag-Cl) electrodes - 2mA (p-p) of 70kHz frequency .
Whereas the Voltage difference is measured across the inner pair of electrodes , now if I feed this into a Instrumentation INA111 amplifier (gain 10), the output is not accurate , the gain is more or less than expected .
Signal 1 : 2.3Vpp , 68kHz
Signal 2 : 2.1Vpp , 68kHz with phase shift;
difference - 200 mVpp to be amplified
Possibility of Phase shift induction might cause this variation , now since the signal is not generated ,
What is the possible way to phase synchronize these two signals before feeding into the Instrumentation Amplifier ?
Is there a way possible with analog signal processing like PLL(Phase locked loop ) or Do we really have to digitize the signals and use the signal processing methods like Cross-correlation or so ? Find attached schematic.
Thanks in advance .
Thanks in advance .
