I've been using fixed 3volt LDO regulators, but I want to be able to allow any voltage from 3v - 6v. Are there similar components that will allow this?
I was hoping for a simple surface mount component, some type of IC. I'm not very familiar with what is out there.Have you considered a buck/boost switching regulator. These can provide a regulated output voltage which can be greater or less than the input voltage. Not really worth building as there are many available on ebay at very low cost.
This type of thing:
http://www.ebay.co.uk/itm/2-24v-Input-DC-DC-2A-Adjustable-Step-Up-Boost-Power-Supply-Converter-Module/301475077594?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20140122125356&meid=af28ab514864442ebae5c6991613231f&pid=100005&rk=2&rkt=6&sd=400858208676&rt=nc
Since I use 3v batteries I really need to limit the output to 6v, but still allow the 3v bulb to function normally if the input is only 3v.Well... If, as you say, the devices operate properly at 6v, your course would seem obvious? Am I missing something?
Regards
HP
It would not reliably pass the 3v 'through' if that's what you mean -- I strongly recommend you take the former poster's advice (Re: the linked devices)If I used a 6v regulator would it still function at 3v?
A diode "OR" arrangement may be useful -- though you'd need to select diodes exhibiting a low forward (bias) 'drop'...I was hoping for a simple surface mount component, some type of IC. I'm not very familiar with what is out there.
Since I use 3v batteries I really need to limit the output to 6v, but still allow the 3v bulb to function normally.
Thank you for taking the time to show me this.
Would you mind being a little more specific?use a J113 fet in constant current mode,
uses just 2 components one transistor and one resistor .
This is a constant current? But does not cap the voltage at 6v?you can use the Jfet with a resistor between the Gate and Source like this
http://www.vishay.com/docs/70596/70596.pdf
It is a head mounted flashlight system. It can use 6v surefire incandescent or LED lamps, or 3-9v Solarforce lamps with a variety of battery types.If you want to shut off above a certain voltage you need a Comparator circuit, not a constant current,
the constant current keeps the same level irispective of the voltage variation.
What are you trying to make?
