How to measure single LED SMD bead voltage from tv led strip?
malgitobi
Joined May 29, 2019
My tv screen suddenly became much much darker and I dissasembled it. When I turned the tv on I saw 3 LEDs are not working. So I removed the strips and then removed the broken leds only. The problem is I don't know what kind of LEDs I need to replace them. With these 3 leds removed my strips are not lighting anymore (I guess because the circuit is open) and I can't put them back because they physically broke in the process of removing them.
There are 6 leds on strip and 3 strips, so 18 led beads in total.
I'm so angry with myself doing such a stupid thing but I'm only first year student and don't have the exprience.
Is there any way to find out single led smd bead voltage without removing it from the strip?
On the strip there is writing: SH S12 94V-0 N 1510
narkeleptk
Joined Mar 11, 2019
599
Does it have the the voltage output marked where that red/black wire plugs into the power supply?
My guess the leds are 3V...
Just googling the number you provided returned a slew of information.
bwilliams60
Joined Nov 18, 2012
1,450
The strips I have seen run on 30 V but I suspect this one will be lower, in the area of around 18V. You can order THE LED strips from Shopjimmy.com using the model number or you can measure length x width to come up with the size you need to replace them individually. You have done nothing wrong. All part of learning.
Dodgydave
Joined Jun 22, 2012
11,395
These are 6V leds in series totalling 108V,, see post #4...
28,496
For a temporary fix you could replace the missing LEDs with resistors calculated to drop the same voltage at the listed current. Less light, but cheap, easy, and fast.
