How to measure inside dimensions of a sloping side box
AlbertHall
Joined Jun 4, 2014
12,660
Will a Fish Tank work?
kv
Most fish tanks would be way too big for my purposes. I'd rather not have many gallons (one gallon is bad enough) of not very nice chemicals slopping around.
Hence my attempt to use the smallest box I can get everything in that I might need to.
shortbus
Joined Sep 30, 2009
10,049
A framework of nylon and ABS to support electrodes for electroplating and the object to be plated
Any electroplating I've ever seen, they did it in two of the places I worked and used to go to pickup plating in another job, the anodes and work hung form the top of the tank, and were not clear out to the edges of the tank. This was to allow the dissolved material easy access from all sides of the anodes to all sides of the work being plated.
wayneh
Joined Sep 9, 2010
18,181
A framework of nylon and ABS...
Well, that would be shape-able. You could make it a couple mm large and shave it down with tools. I think I’d try to use a table-saw set to the angle of the slope, 5 degrees or whatever. Then run the framework along the fence and shave off half a mm at a pass. Maybe round the edge to match the bottom curve on a router table.
AlbertHall
Joined Jun 4, 2014
12,660
It's not worth buying a table-saw for.
