How to make LM317 output voltages less than 1.25 V
Evan Moore
Joined Dec 18, 2021
8
Hello!
I am trying to build a variable dual power supply, and I think I have most of the circuit planned out. however the only thing I do not have planned is how to get the power supply to supply voltages less than 1.25V. I have read online that in order to do this instead of starting the LM317 at 0v to whatever you max out at, instead you start from -1.25V, is this correct? If it is how do I do this? The only way I know how to produce a negative voltage off of the top of my head is to reverse the power entirely, but then I would only be able to give the control pins negative voltage only.
dl324
Joined Mar 30, 2015
18,523
Welcome to AAC!
Yes, you connect the resistor on the adjust pin to a negative voltage. It needs to be at least -1.25V, but can be more negative.
Show us what we have to work with. Are you using a transformer for the unregulated voltage? If not, you can use an inverting switching regulator to generate a negative voltage.
Evan Moore
Joined Dec 18, 2021
8
Here is the LTSpice file, I removed the LM317 and LM337 but I put text where it goes, I only started using LTSpice a week ago so I am not sure how sharing third party subcircuits works, so better safe than sorry. Anyways I am currently using a potentiometer (two resistors) as a voltage divider to vary the adjustment pin of the LM317 and LM337, so currently It only works for positive voltages. I have not actually hooked it up because I wanted to be able to have the output start at zero, and I am not sure if you have to put a negative voltage in the adjustment pin of the LM337. Anyways I hope this helps.
dl324
Joined Mar 30, 2015
18,523
Using LTspice to simulate simple voltage regulator circuits seems like a waste. It's akin to using a calculator to add 123 +234...
The National Semiconductor datasheet showed how to do it for LM317:
Evan Moore
Joined Dec 18, 2021
8
Ok thank you! I was honestly just using a simulation to help wrap my head around it to make sure I have a schematic for when I breadboard it, and just as a sanity check. Also is R5 a mistake? because that would just be a resistor
dl324
Joined Mar 30, 2015
18,523
You'll learn more if you do it yourself, even if you burn up some components. An inexperienced person using a simulator before understanding the basics could find themselves in a position where they can't do much without one because they never took the time and effort to learn the basics. That's why you weren't allowed to use a calculator in school until after you should have mastered arithmetic by rote.
It's not a mistake. It's an omission. I didn't connect it because I didn't want to think about whether you wanted clockwise to be increasing negative voltage or decreasing.
