How to make go from 12V to 19V with resistors
Batista230
Joined Feb 11, 2009
14
Hi
I have a bag of different size resistors and I want to run a 19 volt laptop from a 12 volt DC car battery
I have been told if I run the resistors in parallel it would increase the voltage
I don’t know as of yet the amperage use of the laptop but I know it will be 19v
I know little of ohms law
The question is what size resistors do I need
Also could I run my laptop and charge it direct from my 12 volt source
Thanks
Batista230
Adjuster
Joined Dec 26, 2010
2,148
What you have been told is wrong. It is not possible to increase voltage using a circuit built only of resistors.
What you really need is a switched mode converter, but these are not easy things for a beginner to make. Commercial adaptors are made for running laptops from a 12V supply, I would suggest you try to obtain one of those.
SgtWookie
Joined Jul 17, 2007
22,230
Not just with capacitors and resistors. It also requires an inductor or broadband transformer, transistors or MOSFETs, and controller ICs.
Laptops usually require several Amperes of current.
This would not be something for a beginner to try to make. It requires much more advanced skills, and at a minimum an O-scope (oscilloscope) for test/troubleshooting.
tom66
Joined May 9, 2009
2,595
Technically you can build a charge pump with capacitors and a few MOSFETs, but they aren't much good for anything more than 50mA. ;)
To the OP, here is an adapter sold by Dell. I bet you that all the money you will spend developing your own will be more than this one.
Other manufacturers make their own.
22,114
Probably not, but the brick will run fine from say a 400Watt Inverter. It doesn't even have to be a true sine wave inverter.
iONic
Joined Nov 16, 2007
1,662
Just look for the matching power adapter on ebay and take the cost bite. It will get you going faster and for less money and stress.
