How to make battery level
k1ng 1337
Joined Sep 11, 2020
1,038
Hello
I want to make 9v battery level indicator when i change voltage it should 3v and 6v and 9v led
I'm having trouble understanding your English but that is ok. I think you want to make a battery tester for 9V batteries? If so it would be something like this?
1 LED on = 3V
2 LED on = 6V
3 LED on = 9V
If so, there are many ways to make a circuit, what is your level of electronics knowledge?
WBahn
Joined Mar 31, 2012
32,823
I think that he wants to make a voltage indicator that lights one LED for each 3 V of voltage, So 2 LEDs would indicate that the voltage is at least 6 V but less than 9 V.
@mumbai: Is that close? Please tweak the description as needed.
Why are you doing this? Is it a school assignment?
What is this circuit being powered by? The battery that you are indicating the voltage for?
How accurate to the thresholds need to be?
Do the LEDs need a sharp turn on?
k1ng 1337
Joined Sep 11, 2020
1,038
Here is a circuit I made with LTspice. The graph is showing a simulation where the supply voltage increases from 0 to 12V. The first LED will turn on at about 3V depending on the colour you choose. The second will turn on at 6V and the third at 9V. The circuit costs a few dollars to make and I can test the circuit if you want.
k1ng 1337
Joined Sep 11, 2020
1,038
Whomever came up with that didn't think it through very carefully.
What about mine? I appreciate the honest critique. I think it's too complex for him but was fun to make. I think we wants to build the kind that adds the forward voltages of the LEDS. In that case, he will probably be disappointed. :p
Alec_t
Joined Sep 17, 2013
15,117
If the battery is a PP3 and its voltage is much below 8V then the battery is as good as dead for some applications. Monitoring the 6-9V range might be better.
Ya’akov
Joined Jan 27, 2019
10,235
Having an LED that lights for 9V means you are wasting an LED since it will almost never be lit—if ever. The top indicator should be less than 9V to be useful.
Audioguru again
Joined Oct 21, 2019
6,826
I agree that most of your battery voltages show a dead battery that does not produce enough energy to do its job but it might dimly light an LED. Then the dim LED will kill the remaining power from the battery.
DC_Kid
Joined Feb 25, 2008
1,242
Small comparator IC, you can find them 4 on one IC. Then just tune the thresholds accordingly. Many of them won't even need a drive transistor for LED.
