How to make a switch whithout any other connections in LTSpice ?
Marus780
Joined Jan 11, 2023
92
I want to have a clean switch on my schematics, without the voltage source that controls it. That I will put it on a side...
I tried to modify the classical switch and pass the nodes for the voltage source that controls it, as parameters, but it does'n work...
Do you have an idea how to do this ?
ericgibbs
Joined Jan 29, 2010
21,654
hi Marus,
Welcome to AAC
May I ask why this type of control is required, there maybe other ways to achieve the same result.
E
Marus780
Joined Jan 11, 2023
92
Because my schematic look ugly with that voltage sources, that controls every switch, all over the place. I want to put them on a side of the schematics, with no connections to them. I don't necessarily want to do as in my example. I just want a simple switch that I can control it by other means other than adding direct connection to it. It can be controlled in any way, it doesn't matter. As long as it is controlled remotely.
22,116
If the one-time behavior is not what you are looking for in the model for the switch, you could also embed a behavioral source that would be directly controlled by a voltage outside of the subcircuit. The SpiceLine for the switch would contain the expression for the behavioral source.
ETA: The problem is that you can't easily pass an expression to a subcircuit, only parameters which have a numeric value. It should be possible to pass a node name, but the particulars of the method escape me at the moment.
Marus780
Joined Jan 11, 2023
92
Thank you, both !
That's exactly what I did, by taking example from the models attached by @ericgibbs !
And it works perfectly ! Thank you so much !
.SUBCKT SW_PLS sw1 sw2 delay1={delay} width1={width} period1={period} cycles1={cycles}
V1 3 0 pulse(0 1 {delay1} 100n 100n {width1} {period1} {cycles1})
S1 sw1 sw2 3 0 Smod
.model Smod Vswitch(Ron=1u Roff=100G)
.ENDS
Marus780
Joined Jan 11, 2023
92
@ericgibbs This is how I've done:
.SUBCKT SW_PLS sw1 sw2 PARAMS:
+delay=500m
+width=100m
+period=300m
+cycles=0
V1 3 0 PULSE(0 1 {delay} 100n 100n {width} {period} {cycles})
S1 sw1 sw2 3 0 Smod
.ENDS
.SUBCKT SW_PWL sw1 sw2 PARAMS:
+t1=0
+v1=0
+t2=0
+v2=0
+t3=0
+v3=0
V1 3 0 PWL({t1} {v1} {t2} {v2} {t3} {v3})
S1 sw1 sw2 3 0 Smod
.ENDS
But it would be nice if I could add parameters with an undefined number to the version controled by PWL...
22,116
+delay=500m
+width=100m
+period=300m
+cycles=0
S1 sw1 sw2 3 0 Smod
.ENDS
+t1=0
+v1=0
+t2=0
+v2=0
+t3=0
+v3=0
S1 sw1 sw2 3 0 Smod
.ENDS
Use a PWL statement that refers to a file of time-voltage pairs. and don't forget about using the "repeat forever" clause
Marus780
Joined Jan 11, 2023
92
@ericgibbs Yes, that's it !
@Papabravo If find it complicated to use files for this operation...
But I found a workaround to do this for some points:
+t1=10001
+t2=10002
+t3=10003
+t4=10004
+t5=10005
+t6=10006
+t7=10007
+t8=10008
+t9=10009
+t10=10010
V1 3 0 PWL(0 0
+{t1-10n} 0 {t1} 1 {t2-10n} 1 {t2} 0
+{t3-10n} 0 {t3} 1 {t4-10n} 1 {t4} 0
+{t5-10n} 0 {t5} 1 {t6-10n} 1 {t6} 0
+{t7-10n} 0 {t7} 1 {t8-10n} 1 {t8} 0
+{t9-10n} 0 {t9} 1 {t10-10n} 1 {t10} 0
S1 sw1 sw2 3 0 Smod
.ENDS
And the parameter SpiceLine can be like this: t1=0.4 t2=1.2 t3=1.4.... At every time point, it will shich to the other state.
