How To Make A Guitar Work Through a Homemade Boombox?
coolyyz321
Joined Mar 17, 2017
90
Hello, I am making a homemade boombox and want to wire a 1/4” Aux Jack to plug a guitar into. What parts would I need after that to make it work? (The system will feed into the main amplifier)
Is it as simple as wiring a small preamplifier from the 1/4” jack and then into the main amplifier?
Thanks, Cody
ian field
Joined Oct 27, 2012
6,536
Thanks, Cody
Clarify what you mean by "homemade boombox"? A commercial unit probably has 5k volume pots that will just shunt the high impedance pickups. I'd suggest a JFET source follower using the pots as the load resistor. It will pass current through the track and develop voltage across it - you probably need to lift the track from the source select switch.
coolyyz321
Joined Mar 17, 2017
90
This diagram shows where the guitar system would be placed in the boombox. What I mean by a homemade boombox is as shown in the diagram, the audio comes from a car radio which has Bluetooth, CD, Line in, etc. From the car radio is a mono audio signal that feeds into the main amplifier. Which in turn plays through the speakers.
The explanation for the guitar system is the audio coming from the guitar going into the 1/4” Aux. jack that goes into the “circuit in question”. The goal of the circuit in question is to beef up the signal to be fed into the main audio line to be amplified.
Thanks, Cody
ian field
Joined Oct 27, 2012
6,536
Thanks, Cody
JFET source follower.
coolyyz321
Joined Mar 17, 2017
90
Thank y’all for all of you guy’s help, but what transistor, capacitor and resistor values would be good for the JFet source follower circuit?
