How to load 74hc192 with a number
O_0
Joined Jun 3, 2017
5
I wanted to ask on how can I load a number in 74hc192 ? I'm doing a counter circuit with three digits, so I have a counter for each digit, however, it starts from zero and sometimes random numbers. How can I get the counter to start from 9 ? Thank you.
djsfantasi
Joined Apr 11, 2010
9,237
Have you read the datasheet? Can you describe for us what PL, P0, P1, P2 & P3 are?
What are you using the 74HC192 for in the big picture?
WBahn
Joined Mar 31, 2012
33,365
Please post a schematic of how you are using the counter so that we can look for the cause of the random numbers -- there are a few possible reasons.
GopherT
Joined Nov 23, 2012
8,009
Use pins P0,P1,P2, P3 to set the binary value of 9.
Then the value of the output will be set to 9 when the Parallel Load (PL) pin goes from Hi to Lo.
O_0
Joined Jun 3, 2017
5
I did read the data sheet. PO, P1, P2, P3 are the inputs of the counter, I usually don't use those so they are connected to ground. PL is the parallel load, where I can load the counter with a value, I tried connecting logic gates AND to get the value 1001 and the output was inserted in the load but nothing happened.
I think I can add it in the inputs, can't I ?
GopherT
Joined Nov 23, 2012
8,009
You may not normally use them but they are required if you want a preset value. You can simply pull P0 and P3 to High. Then use some logic to trigger a pulse to the PL pin to load the preset value when you want a 9 on the output.
O_0
Joined Jun 3, 2017
5
How can I trigger a pulse ? Can I do that with a push button instead of the clock signal ?
GopherT
Joined Nov 23, 2012
8,009
Yes, a push button works fine. Make sure you use a pull-up resistor to keep a 5v signal on the PL pin until the button is pressed to ground the pin. Google "pull up resistor" if needed.
O_0
Joined Jun 3, 2017
5
Yeah, I've used those plenty of times. Thank you for you help.
