How to let a 7-segment BCD using negative edge-triggered flip-flops to repeat from 9 not F
Chris47
Joined Feb 7, 2021
7
Design a 7-segment displayed binary counter using negative edge-triggered flip-flops which counts between “ID number” and it’s “10’s complement value” in reverse order. It starts with complement value, decrements to your id number, then returns to complement value again, and repeats counting sequence with the applied clock signal.
This was my assignment, i solved it and everything is running correctly, but when the number is decreasing from the complement to my id number it repeats from F, however I need it to repeat from 9. How can İ solve this problem ?
ericgibbs
Joined Jan 29, 2010
21,573
hi Chris,
So you are using an 8 Stage Binary Counter, preloaded with
9181??14 and you need to count down to the 10's complement of
19290096
9181??14
then
reload
9181??14
,,,, and keep repeating.
E
Chris47
Joined Feb 7, 2021
7
hi Chris,
19290096 and you need to count down to the 10's complement of
9181??14
then
reload
19290096
E
The complement is 80709909, it is the complement to 9. Can it be complement to 10 ?
ericgibbs
Joined Jan 29, 2010
21,573
hi,
OK.
80709909 and you need to count down to the 9's complement of
19290096
then
reload
80709909
Chris47
Joined Feb 7, 2021
7
hi,
OK.
19290096
then
reload
80709909
I think i solved the question wrong, it should be through the 10's complement but I solved it for the 9's complement. Or is it true ? Since in binary the maximum number is 9 ?
ericgibbs
Joined Jan 29, 2010
21,573
hi Chris,
If you are using 8 Bit BINARY counters, you will need very complex decoding logic, if you are counting to decode DECIMAL values.
when using an 8 Stage counter.
No, it is 15 == Bits 1111 or 'F'
I would advise you confirm if it is Binary or Decimal
E
Chris47
Joined Feb 7, 2021
7
hi Chris,
E
It is binary, but now i have a problem how will I do it for the 10's complement
ericgibbs
Joined Jan 29, 2010
21,573
hi,
Checking you original circuit image, they are positive edge clocked bistables not negative edge trigger.
How are you preloading the ID value into the counters.?
E
