How to learn if an hot plate is controlled by a thermostat or
123Ken123
Joined Apr 8, 2022
56
How to learn if an hot plate is controlled by a thermostat or an infinity switch? Looked at many hot plates with no indication what type of switch it is. Contacted Human Resources of a hot plate manufacturer gave the plate model and asked for the temperature switch model but no reply and they do not have a parts list for the switch. Might be confidential . Any thoughts how to proceed?
123Ken123
Joined Apr 8, 2022
56
Also wish not to disassemble the plate.
LowQCab
Joined Nov 6, 2012
5,102
No manufacturer is going to use an expensive Variable-Electronic-Controller
when they can use a common Thermostat that costs them ~$0.12 cents each.
Unless You want to start looking at Hospital-grade, Military-Spec, or Industrial-grade, equipment.
