How to give logic 1 to one pin in ATmega16. If I am giving 5v to pin .Its not working
nishkum3
Joined Jun 5, 2017
14
I need to give logic 1 to one pin. I am just giving 5v directly to that pin . But its not working. Not sure what to do..PLesase suggest.
Reloadron
Joined Jan 15, 2015
7,887
Code? Your code would help along with a drawing of the circuit. There is no way to tell what your problem might be without more information.
Ron
MrSoftware
Joined Oct 29, 2013
2,273
If your intent is to read a logical 1 or 0 from that pin, then be sure to set the pin mode as digital input. Also be sure to pull the pin up or down so that it's not floating. The processor probably has a way to turn on internal pull-up or pull-down resistors so that you don't have to do it externally.
nerdegutta
Joined Dec 15, 2009
2,689
How do you know? What are your expectations?
You need to show your code and your schematic, which has been mention. If you have your circuits on a breadboard, a focused picture would do just fine.
