How to generate 3-30VDC (0.5A) from 12VDC?
bludin
Joined Oct 24, 2013
8
I need to generate 3-30VDC (controlled digitally with at least 12bit resolution, e.g. using a DAC)) from a 12VDC power supply. What would be the best way to achieve this? (sorry in case this is a common type of question, but I lack the terminology to search for it efficiently).
TIA, Beat
Papabravo
Joined Feb 24, 2006
22,116
TIA, Beat
What you need is a buck-boost converter with a digitally controlled VCO. Question: How will the DAC know what voltage to select?
https://en.wikipedia.org/wiki/Buck–boost_converter
http://www.learnabout-electronics.org/PSU/psu33.php
AnalogKid
Joined Aug 1, 2013
12,297
Another approach is to separate the buck from the boost. First, boost the 12 V to a fixed 30 V. Then regulate the 30 V with the DAC output with either a buck or linear regulator. More overall parts, but it might lend itself to DAC control over a 10:1 range better than an integrated buck-boost controller.
ak
bludin
Joined Oct 24, 2013
8
Thanks for your answers.
I just want to control the voltage from a microcontroller in whatever way is most efficient. Since I don't need high modulation speed, a DAC with an I2C interface might be good (I usually end up with too few PWM channels, but in principle, PWM could be used, too).
AnalogKid
Joined Aug 1, 2013
12,297
There are two basic types of voltage regulators: fixed reference/variable gain, and fixed gain/variable input voltage. For DAC control, life is much easier with the latter topology. The part mentioned above is of the former type, and has consequences:
1. This part has a fixed voltage reference and relies on a divided output voltage for adjustment. A DAC with a low impedance output voltage will need some kind of circuit to interact with the control loop.
2. The voltage-setting resistor divider is part of the frequency compensation loop. This makes making this regulator adjustable more difficult.
3. The frequency compensation changes as a function of the output voltage.
ak
Papabravo
Joined Feb 24, 2006
22,116
With all due respect -- this is not an answer. I know you want to use a microcontroller to control the DAC, and efficiency has nothing to do with how you intend to decide what voltage to set the DAC at.
bludin
Joined Oct 24, 2013
8
Ok, I guess I didn't understand your question then, sorry about that.
The power supply will drive an array of piezoelectric blowers (via individual resonant driving circuits), the combined flow will be measured by a mass flow meter. It'll be a closed-loop PID system. Thus a perfectly linear response is not that important. Is that what your question aimed at?
Papabravo
Joined Feb 24, 2006
22,116
Not quite. If I understand correctly the mass flow meter will indicate how much air the fans are moving, and that value will determine the output voltage of the supply. So last(hopefully) question how is the information from the mass flow meter given to the processor? If the response is not linear you will have other problems, but that is a discussion for another time.
bludin
Joined Oct 24, 2013
8
OK, so the processor uses the I2C interface to take samples of the mass flow rate on a periodic basis. What happens in the case of an inability to obtain a sample?
It will increment an error counter for the sensor by a, retry, and decrement the counter by b in the case of success. If the counter hits a defined threshold c, the device cancels operation safely, giving an appropriate error message.
Papabravo
Joined Feb 24, 2006
22,116
That answers the questions about the method of closing the loop. You mentioned in an earlier post that you were not concerned about linear behavior. I want to caution you about some of the problems you may encounter with non-linear behavior. The two most important ones are:
  1. Divergent output from unexpected input conditions
  2. Limit Cycling, which is a characteristic of some non-linear systems.
https://en.wikipedia.org/wiki/Limit_cycle
