How to fix this thing - wifi antenna ?
LesJones
Joined Jan 8, 2017
4,544
You have still not said what the problem is. In the right hand picture it looks like you are holding a piece of coax with what maybe a coax connector on the end. The picture is not clear enough to be sure is is a coax connector. I don't know what the significance of the left hand picture is.
Les.
MrSoftware
Joined Oct 29, 2013
2,280
If it's not a connector that you can put back on the wire, then maybe you need to solder the ends back on to fix it? Assuming the detached wire is the problem.
