MisterBill2
- Joined Jan 23, 2018
- 28,227
Here is the simple, cheap, and easy fix, which is to use one of the 3-wire grounding your 2-wire adapters that we have available on the shiny blades, and then plug that adapter into the outlet. The fix is totally reversable and cheap.Just pin config converter. I've tried on quite a few plugs. Most of my plugs are new because it's a new room.
