How to find measured value of voltage using primary and secondary voltages?
gbtbtbt
Joined Mar 18, 2020
72
If you have given values of the primary voltage and secondary voltages,
1.) How do you determine if the voltage is boost or buck with given EP and ES?
2.) How do you find the measured value of voltage with both primary and secondary voltage?
MaxHeadRoom
Joined Jul 18, 2013
30,871
It is only Buck or Boost whichever two conductors, one on each of the primary and secondary, are used as the common reference.
Look up the circuit of a typical buck-boost transformer diagram.
The secondary voltage value will either add to, or subtract from the primary, dependent on which of the two connections are selected, Buck or Boost!!
Max.
gbtbtbt
Joined Mar 18, 2020
72
do you not just add or subtract depending on whether the secondary voltage is lower or higher than the primary voltage? If the secondary voltage is higher, would you add both voltages together and when secondary voltage is less than primary, would you then subtract both voltages?
MaxHeadRoom
Joined Jul 18, 2013
30,871
There is no unique, buck or boost transformer, just combined buck-boost and the result all depends on the phase of the buck/boost winding WRT to the voltage of the supply transformer it is acting on.
Max.
DickCappels
Joined Aug 21, 2008
10,661
I am going to make a guess: gbtbtb is asking about simple AC transformers, such as a filament transformer as one might use to power a small project, but is using terms that we associate with switching power supplies. Hence, the confusion.
@gbtbtbt are you talking about an old fashioned transformer or a switching power supply?
Alec_t
Joined Sep 17, 2013
15,160
I think this TS's thread is related to his other one, which involves a simple old-school transformer with only two windings.
gbtbtbt
Joined Mar 18, 2020
72
We used a fully protected transformer from the brand Lab Volt. It looks like a relatively simple transformer, fitted with three discrete windings. As well I was told that to find boost or buck connections depends on which is greater Ep or Es. If Ep is bigger than you would subtract with Es, however, if Es is bigger than you would add with Ep.
MaxHeadRoom
Joined Jul 18, 2013
30,871
A typical application is required when the secondary of a transformer is too high (or low),
A second transformer can be used to buck or boost the secondary.
Both transformer primaries are wired across the main power supply, the secondary of the Buck/Boost one is wired in series with the secondary of the main transformer.
The voltage will buck or boost the main secondary output depending on the phasing of the winding, one way it will subtract, buck, the other add to or boost.
Max.
