How to find LED Voltmeter with enough digits displayed?
Joined Mar 20, 2017
10
I'm trying to find a small LED, white or blue text color, that can read from 0.00 to 9,99 volts
Can someone point me to a good suggestion?
My concern is I need to be able to display for example 0.01 up to 9.99 but most only do tenths not one-hundredths of a volt.
Thanks a bunch!
Reloadron
Joined Jan 15, 2015
7,891
So you want a 0 to 9.99 VDC meter which resolves 10 mV. Just make sure the meter you choose is also accurate to 0.01 VDC. The fact a meter can resolve 0.01 VDC does not always mean it is accurate reading 0.01 VDC. What accuracy would be acceptable?
Ron
Joined Mar 20, 2017
10
Ron
.05
Reloadron
Joined Jan 15, 2015
7,891
Looking at a .05% uncertainty I doubt you will find what you want in a cheap off the boat meter from China. You are looking at DPMs (Digital Panel Meters) with a higher cost, like this one from Omega.
Voltage Input: ±100 mV, ±1 V, ±10 Vdc scalable
Process/Strain Process Voltage ±50 mV, ±100 mV, ±1, ±10 Vdc 0.03% FS
All a matter of what you want to spend for a DC Panel Meter with the resolution and uncertainty you want. There are a dozen companies marketing what you want, the link is just a single example. Actually while it has an Omega label I am not sure who actually makes it.
Ron
