How to drive source follower (with feedback) with an op amp
BufkinMK
Joined Apr 28, 2022
7
I have an NMOS transistor in source follower (common drain) configuration, but with feedback from the output to the input. It is to be used as a power stage, as the power to the load is high.2022-04-29 (4).png How can I replace the voltage source with an op amp ?
Anything to point me in the right direction would be much appreciated.
Thanks.
38,784
That circuit looks a little odd.
What is its purpose?
It looks somewhat like a current-drive (constant-current) circuit, but the current will depend upon the MOSFET Vgs threshold voltage, and I would assume you don't want that.
You can't readily substitute an op amp for V2, since that is a floating source.
And that's not a source-follower circuit.
A source-follower output is the MOSFET source.
BufkinMK
Joined Apr 28, 2022
7
The purpose is to act as a power gain stage for an op amp. It should be in the op amps' feedback loop, which is proving difficult, as you say.
But it effectively functions as a source follower?
Thanks for the helpful information
38,784
Not really.
I just wasn't sure what you were really trying to do.
Below is the basic circuit for an op amp driving a MOSFET as a source-follower.
Some additional compensation parts may be needed for stability, depending on the frequency response you need and the op amp used.
BufkinMK
Joined Apr 28, 2022
7
Not really.
Thanks very much. Is it possible to add voltage gain to the op amp stage?
BufkinMK
Joined Apr 28, 2022
7
Not really.
Can you explain how this circuit produces the bias voltage required to turn on the MOSFET, even at a very small input voltage (much less than the threshold Vgs)?
Thank you
38,784
The high open-loop gain the of the op amp means the output will go to whatever voltage is needed to turn on the MOSFET, so that the difference between the plus and minus op amp inputs is very near zero volts.
This circuit only seems to work for feedback resistors of equal value.
Why do you say that? What's so special about them being equal value?
It will work for any arbitrary values within the limits of the circuit components and voltage supply.
38,784
Here's the simulation of the circuit with a (arbitrary) gain of 10:
Note how, due to feedback, the MOSFET gate voltage (red trace) is biased by the op amp output to the value needed to generate the proper follower output centered at 2V (yellow trace) for the input centered at 0.2V (green trace).
BufkinMK
Joined Apr 28, 2022
7
Thank you, I don't know why this wasn't working for me.
Is the 0.2v DC bias on the voltage source is the only reason the MOSFET is in the active (linear) mode of operation? Is there any way to bias the MOSFET without manually selecting the 0.2v DC bias? I have tried a potential divider at the MOSFET gate but that doesn't seem to work.
Thanks so much for your help.
38,784
Yes.
Otherwise the output would be 0V when the input sinewave is 0V and the bottom half of the sinewave would be clipped.
You can't offset the MOSFET gate because you are fighting what the op amp is trying to do (maintain the output equal to the input).
The offset must be done at the op amp input.
You need to read some tutorials on how op amp feedback circuits work, as you seem to not understand that.
If you don't want to bias the source, then you can use a voltage divider to generate the input bias and then use capacitive coupling to block the DC.
That will only work with an AC signal, of course.
Simulation below:
If you only have positive signals, then you don't need to bias the input.
Also note that a single-supply type op amp would be needed in the actual circuit.
