How to discharge battery from Samsung?
UnnamedUser159
Joined May 3, 2016
501
It is from the normal "type" - It has two connections - + and -
If i can discharge it quick and safe maybe would be good.
If not how much time to put away to full discharge?
The idea : want to sell the battery because it`s good and want to make it full charge and tell in my ad that it was charged "for couple of hours"
Dodgydave
Joined Jun 22, 2012
11,395
Discharge time depends on how much current for how long time,what's the capacity of the battery?
UnnamedUser159
Joined May 3, 2016
501
At all
I can do that with every phone battery? Is there some recommended Current for discharging?
I think to purchase couple of resistances and can discharge every battery i have.
I will multiply the voltage and the current and calculate the minimum W the R should be.
gramps
Joined Dec 8, 2014
86
IIRC, lithium cells will be irreversibly damaged if fully discharged (to 0 volts) and shouldn't be discharged below 3.0 volts. Long term storage voltage should be about 3.80 volts. YMMV
