How to dim led circuit?
NVZN1
Joined Dec 17, 2016
35
Hello, I have a desk light that can be dimmable by touch sensors. Unfortunately it failed, and I managed to know their working voltages.
Powered by 4.2v max 18650 lithium,
Very dim light : 2.3V
Maximum brightness : 2.7V
Now I wanted to bypass the original circuit since it failed, can I do this with a potentiometer as dimmer and on off switch?
If yes, I need the diagram illustration.. Because I'm quite newbie in this sector... And also how many K ohm potentiometer needed?
Thank you!
DickCappels
Joined Aug 21, 2008
10,661
Do you mind building a simple electronic circuit using an inexpensive 8 pin integrated circuit?
You need to choose resistors that limit the LED current to whatever your LEDs can handle. If describewhat is conneceted to the LED, particularly resistors, we might be able to get you close to the right value.
Here is a Google search that found this and many similar circuits:
https://www.google.com/search?q=led...HZKxAqAQ_AUoAXoECAEQAw&biw=1298&bih=900&dpr=1
NVZN1
Joined Dec 17, 2016
35
Does 555 support 4.2v input?
Jerry-Hat-Trick
Joined Aug 31, 2022
843
How about:
This assumes that it's a single LED and the maximum current is 20mA. I'm thinking, typically a white LED has a voltage drop higher than 2.3 to 2.7 Volt so I do wonder if something else is going on? Not as elegant as a 555 with variable mark/space but quick to make!
Audioguru again
Joined Oct 21, 2019
6,826
Your 18650 Lithium-Ion battery cell is not always 4.2V. Its voltage drops to 3.0V as it is used,
The LM555 and NE555 both have a spec'd minimum supply voltage of 4.5V so they will not work with your battery cell.
My solar garden lights lightup a 3.2V white, blue or colors-changing LED when the battery voltage drops to 0.9V with a voltage stepup circuit.
