How to detect a fluctuating voltage signal
Nick Long
Joined May 12, 2020
75
Hello! I want to design a circuit that can detect a fluctuating voltage signal. The specific function I want to realize is described as follow:
As shown in the figure below, I want to output a high voltage when the peak value (in the blue circle) of the signal (the red line) is lower than a threshold. For example, when the peak value in the blue circle is lower than 0.05V, a component, like the voltage compartor will output high. I hope the circuit realization is as simple as possible.
Do anyone have a good idea to achieve that? Thanks.
35,159
Yes it can be done.
But before we run around in circles, tell us exactly what you are doing. We want to hear more than just when a peak is lower than a threshold. What is the application?
Nick Long
Joined May 12, 2020
75
Yes it can be done.
I want to monitor the Glucose concentration. This voltage signal is the output of a Glucose concentration sensor.
35,159
Usually one wants to detect when a peak exceeds a threshold. This can be done using an analog comparator.
Your graph does not represent glucose concentration to me.
I would expect it to look more like this graph:
or this:
Nick Long
Joined May 12, 2020
75
or this:
It is the output voltage curve from the Glucose concentration sensor, not the Glucose concentration curve. The difficulty is that the voltage signal fluctuates with time. The Glucose concentration will cause the peak value of the output voltage of the sensor to vary. Note that the fluctuation always exists, the change is mainly the peak value. Different Glucose concentrations correspond to different peak values.
Alec_t
Joined Sep 17, 2013
15,156
There are three main stages:
1) Amplification
2) Peak-detection
3) Threshold comparison
Stage 1 is analogue only, but stages 2 and 3 could be done with a micro-controller.
Nick Long
Joined May 12, 2020
75
1) Amplification
2) Peak-detection
Yes. Do you know how to achieve peak detection? I don't want to use the ADC to find the maximal value.
