How to design a special voltage function?
Teddy Doloir
Joined Feb 9, 2019
15
I want to convert analog voltage as below:
if input 0V : output 1.6V
if input 5V : output 0.6V
I can i do that? Using which circuit?
Alec_t
Joined Sep 17, 2013
15,156
Welcome to AAC!
It's doable. What are the input and output tolerances you need?
What provides the input signal?
Do you want to use discrete components or a microprocessor?
Teddy Doloir
Joined Feb 9, 2019
15
Voltage provides from DAC circuit (LTC2644) Because I convert pwm duty to a voltage range 0V-5V. And after that, I need a linear precision 0.6V to 1.6V with confortable tolerance using discrete components (no microprocessor).
ericgibbs
Joined Jan 29, 2010
21,567
hi TD,
There is a circuit error on that diagram, I will correct and repost.
Eric
EDIT:
Corrected input circuit, reposted. in post #6
ericgibbs
Joined Jan 29, 2010
21,567
hi Teddy,
This circuit is for
Added:
Set Up
1. Set the Vinput Source of the 1st OPA to 5v, adjust R7 so that Vout of the 1st OPA is 1v.
2. Set the Vinput Source of the 1st OPA to 0v. adjust R2 so that Vout of the 2nd OPA is 1.6v
3. Reconnect the Vinput Source to the DAC output.
I will leave the earlier circuit posted, just in case you have it reversed, like I did.:rolleyes:
I misread as:
if input 5V : output 1.6V
if input 0V : output 0.6V
Eric
38,780
Here's a single op amp version:
The minor disadvantage of this single amp is that the offset voltage is affected by the gain setting, so you must first set the gain to give a 1Vpp signal swing, and then adjust the offset (which does not affect the gain) to the desired value.
