How to create clearance around shape in HFSS 3D layout?
zapallo
Joined Dec 14, 2025
I want to draw this in "HFSS 3D layout":
In the top layer I created a rectangle and assigned the net `GND` to it. Then I created a line and assigned the net `signal` to it. I get this:
Now I would like to create the gap that separates these two conductors that has distance `S` in the drawing. Do you know if it possible to have this done automatically, in a similar way as it is done for the antipads of a via, and preserve the parameterization?
The only way I found to do this is manually cutting the ground plane, however this is not parametric, i.e. the new shape is a static shape. I also tried drawing a thicker line and setting it as "negative", however in this case all the conductor material is removed, including the line.
Rf300
Joined Apr 18, 2025
126
You are asking a question about a 5-digit-$ software. So I assume this is not a hobby project but a commercial one. Therefore commercial rates apply.
My recommendation is either read the thousands of manual pages (which are really good) or ask an ANSYS FAE.
