Mechanical engineer here. My job is heavy with electrical work but I don't have a ton of training in EE. So looking for help on this one. As the title says I am looking for a way to create a circuit that outputs a linearly changing voltage from 2.3V to 2.6V upon receiving an input signal.
The input signal will be either 12V or a short to ground.
With no input signal, output voltage should read 2.3V.
Once that input signal is received I need to start ramping up the output voltage to 2.6V at a specified rate. Still working on what that rate should be. It will then sit at 2.6V until the input signal is removed.
When input signal is removed the voltage can go right back to 2.3V. Rate of decrease does not matter.
Any help is greatly appreciated.
