Can you use the .asc I'm enclosing to see if it works as it should? It takes longer than it should to make it run. Please replace the existing opamp with the OPA1611. Please do tell me if you need any other file. Look at how fast the results show running with the LT1115.Hello
You don't have to make a symbol.
You can use the opamp2 symbol supplied with LTspice.
The opamp2 symbol is in the opamps section in the component selector.
After you place the opamp2 symbol on the schematic, change the symbol "value" attribute to OPA1611.
Make sure the OPA1611.LIB file is in the same folder as the schematic.
Add the directive .lib OPA1611.LIB so LTspice will know where to find the model file.
See attached Test Circuit.
