How to connect differential outputs for detecting RF signal from avalanche photo detector (2.5G APD
Nd Afridi
Joined Dec 13, 2016
How to connect differential outputs for detecting RF signal from avalanche photo detector (2.5G APD TIA module) .
how to check for pin configurations as company didnt provide me datasheet.I myself downloaded a similar datasheet but still I am not sure about correct pin configuration.
http://www.wooriro.com/english/img/product/spec-pd/(WOS-E-1320-02)2.5G APD TIA TO.pdf
I am using 2.5G APD-TIA Photo detector module.It has differential outputs, out and out(q).how can I connect differential outputs to make it single ended output.Can I use voltage Balun ?
thanks
Nd Afridi
Joined Dec 13, 2016
Dear Cappels, Thank you for the help.Can you please tell me how can i connect differential outputs i.e Data P and Data N?
Actually I need single ended output for my circuit.I used video balun to connect data P and data N which converts to BNC.I wonder if this is the correct way or i am doing something wrong ???
Please look at the Balun i used on the link
http://www.devicemart.co.kr/38548
DickCappels
Joined Aug 21, 2008
10,661
I don't have any experience with this kind of detector but I am confident that somebody with helpful ideas will soon come along soon.
