How to connect a relay
MikeML
5,444
I am not able to understand where to connect switch in relay. I.e to which terminal of relay
What are you trying to do? Be as specific as possible.
The circuit you linked to was created by a total newbie; if you tell us what you are trying to do, we can likely come up with something much simpler...
Shubam Agarwal
Joined Oct 1, 2015
6
The concept is when I push the button then relay should be energised and even when I release push button it should glow led for few seconds depending on rc time constant
12,156
That is not your fault. This is one of the worst project descriptions I've ever seen. There are ten statements under "Circuit Operation", and eight of them are wrong. The schematic has critical errors, missing parts, and just generally makes no sense. There are dozens of people on this forum who will gladly help you design a better circuit. It will take less time than explaining all of the things wrong with the one you have.
SO - what is it you want a circuit to do?
30,686
I have no idea why they used a relay to switch that simple circuit?
Why the P.B. was not used directly is a mystery!
Appears a very poor design to achieve what they say.
Shubam Agarwal
Joined Oct 1, 2015
6
I want to design a circuit which works on that concept...
KMoffett
Joined Dec 19, 2007
2,918
Do you want to design a circuit...or...do you want a circuit designed to do your concept?
Battery + capacitor + 3 resistors + PB switch + LED + N-channel MOSFET. Circuit will have the LED fade out, or add a relay for sharp cutoff.
Ken
Shubam Agarwal
Joined Oct 1, 2015
6
I want a ckt to work for
Ken[/QUOT
Ken
I want a ckt to work for my concept
ErnieM
Joined Apr 24, 2011
8,415
Unfortunately there is no "concept" to follow here as the circuit cannot work, period. Even assuming the box labeled "push button" has a power source to turn on the relay the lamp will just turn on and off with the same push button, there is no delay.
A simpler circuit to do the very same action is just the 9V battery, the push button, and the lamp. The rest is just junk that has no function.
So, we ask again: what do you want the circuit to do? Is that turn on with the button, then turn off after some delay?
The more detail you tell us the better we can assist you.
Shubam Agarwal
Joined Oct 1, 2015
6
Ya my concept us to turn on with push button and off after some delay after I release the push button
12,156
What is the power source for your light?
What is the power source for your timer?
What light or how much light so you want to control. Ken's circuits show a single LED, but with the relay you can control a larger light source.
