How to choose the right Lithium Ion battery for your project?
nikolasgioannou
Joined Aug 3, 2019
12
You will need some way of generating the pulses to control the speed of the motors. I would recommend an Arduino microprocessor module. It is fairly simple to use and there are lots of application examples on the internet. It will interface directly to the motor controller you have chosen.
There are a couple of ways to measure the speed of a motor. You can use an optical tachometer circuit or you can measure the back EMF of the motor which is proportional to its speed. Once you have a signal that is proportional to the motor speed, you can compare it to a reference and program the microprocessor to change the ratio of the pulses to maintain the correct motor speed.
If you do not feel confident enough to tackle a project like that, I would recommend that you use a simple speed controller and voltage regulator to compensate for changes in the battery voltage.
Here is a suitable motor speed controller:
https://www.aliexpress.com/item/328...chweb0_0,searchweb201602_4,searchweb201603_52
Here is a voltage regulator:
https://www.aliexpress.com/item/329...chweb0_0,searchweb201602_4,searchweb201603_52
Thanks so much! This is making sense! Would it work to use this as I had it from before?
jpanhalt
Joined Jan 18, 2008
11,087
As previously asked, we do not know what power and speed of motor you need. Before spending a lot on controllers, I think the best place to start is with the mechanical. That is, you need to know which motor(s) you will be using before trying to decide which components you need to control it/them.
I have no experience with tennis ball launchers, but I do have experience with model sailplane launchers. The power requirements can be surprisingly high as you must go from standing still to release velocity relatively quickly. For a tennis ball that weighs about 2 oz (60g), a serve requires about 70 joules of kinetic energy (http://johnericgoff.blogspot.com/2012/01/tennis-balls-and-kinetic-energy.html ).
Since you apparently have plans for the launch system, my suggestion is that you build that first. Then find a motor(s) that will work with it. And finally, decide on what batteries to use. You mention using 2 motors at the start of this thread. Presumably one is to feed the balls and the other runs the paired wheels to accelerate it. You could use two to accelerate it (i.e., drive top and bottom wheels). That might allow you to put some killer spin on the balls, but is it necessary? In any event, how you make the launcher is up to you, and it probably will require some trial and error, but it is where I suggest you begin.
nikolasgioannou
Joined Aug 3, 2019
12
Thank you for the information. I will do some experimenting. I really appreciate the time you put in to help!
