If the line driving pin 8 is open circuit then a DMM connected between pin8 and ground will read +15V, because the meter resistance is much greater than the K1 coil resistance.It should be LOW on 8.
HiI have this circuit
I am suspecting the Q3 or K1 is bad.
When I apply 15V to K1.
I am seeing +15V at 4 and +15V at 8. It should be LOW on 8.
How do I go about checking to see if this K1 is faulty?
thanks
