how to check if the correct resistors are installed
pancake
Joined Oct 30, 2013
5
i have this speedo gauge that has been previously repaired it has been removed from my bike as it has been draining my battery the clocks on this model of bike are common to fail and are VERY expensive my question is how can i safely identify the correct value of resistors (remember the resistors are not origonal and i cannot get any circuite diagrams) i will try and upload pics thanks all
mcgyvr
Joined Oct 15, 2009
5,394
read the color bands... or the number on them if surface mount.. resistors typically cannot be measured with an ohm meter/multimeter "in-circuit"
be careful where this post goes.. Discussions of automotive/vehicular modifications are not allowed here.
GopherT
Joined Nov 23, 2012
8,009
I am sure the OP is referring to his bicycle. So, assuming the resistors are not burned or covered with glue, read the resistor color code and replace them. My question would be, how do you know the resistors are bad unless you see physical damage?
30,806
The basket is on the rear carrier.
The bell is required by law.
Sticking out behind the bell is the rear view mirror.
The red button on the left handle bar is the switch for the light.
The right handle bar is the throttle.
pancake
Joined Oct 30, 2013
5
they are completly black no coulour codes on them
pancake
Joined Oct 30, 2013
5
its not a mod its a repair
pancake
Joined Oct 30, 2013
5
so the question remains how would i (or you) go about finding out the correct resistor value IF THERE IS NO COULOUR BANDS SHOWING and there are no circuite diagrams etc
30,806
Assuming that the resistor has not been damaged you can unsolder the resistor and measure the resistance with an ohmmeter.
Wendy
Joined Mar 24, 2008
23,421
Is this for you bicycle?
What is the make/model of you speedometer?
Do the resistor go between your generator and the clock?
There just is not enough information here.
Guys, please keep this on topic for the OP.
