How To Charge A Lead Acid Battery ?
Mc7- gamer
Joined May 26, 2016
20
I have recently purchased a 12 volt lead acid battery.
I have linked a photo below
I am going to be using it to power 3x 12 Volt fans that only draw 0.15ma
I was wondering what voltage I would have to charge it at (I wan't to be realy sure I don't damage the battery so maby leave some room in there)
Also can I charge it with a lab bench power supply my model can output 30 Volts At 3 Amps (It doesn't have to charge quickly I just want to preserve it :)
If so what do I charge it with
I have seen people using a multi meter to monitor the voltage when charging
Thanks Robbie
ericgibbs
Joined Jan 29, 2010
21,649
hi Mc7,
It is a SLA [Sealed lead acid] battery.
Do not discharge below 10.8v , preferably 11v.
Recharge at 13.8v
You should use a SLA charger.
E
ericgibbs
Joined Jan 29, 2010
21,649
hi,
You could use your bench power supply, ensure the voltage output is set to 13.8V
I use my PSU to charge SLA, set at 13.8v.
E
ericgibbs
Joined Jan 29, 2010
21,649
hi,
No, the battery will only draw the current it needs to recharge.
It will start at approx 0.5 Amp falling to approx 0.1A as it charges.
If your PSU has a current meter you could monitor the current and voltage as it charges, that will give you an idea of the condition of the battery.
Lets know what you measure.
E
bertus
Joined Apr 5, 2008
23,032
Looking at the picture, the recommended charging voltage is 13.5 Volts:
Set a Bench power supply to 13.5 Volts.
Add a resistor of 10 Ohms in series to reduce the starting charging current for protection.
Bertus
Mc7- gamer
Joined May 26, 2016
20
Ok so something like this (I know best drawing in the world :) )
stop using battery at 11 volts then charge it
So start charging at 13.5 Volts and limit it a 600 Mili Amps
It will draw 0.5 Amps and slowly drop
Is this it, when it is done it will draw 0.1 Amps ???
Mc7- gamer
Joined May 26, 2016
20
I can't do it now but I can do it next week
I don't have access to my power supply before then
Do I really need the resistor
Mc7- gamer
Joined May 26, 2016
20
What I will do is be using it to drive 3 Fans
I will monitor the voltage with a display and when it gets down to 11
Turn it off and then hook it up to my power supply voltage limit it a 13.5 Volts and Limit it at 600 Milli Amps
Then when the amp display shows it only drawing 0.1 Amp turn it off
Then I can use it again
That is basically all I will be using it for
bertus
Joined Apr 5, 2008
23,032
On the battery is given "initial current less than 0.39 A"
When the battery is 11 Volts and the power supply is 13.5 Volts, the 10 Ohm resistor will set an initial current of 0.25 A.
Bertus
ericgibbs
Joined Jan 29, 2010
21,649
hi,
With any project powered from a SLA or high capacity battery, I would use a fuse in the +12V line to the load [your fans]
A 1 amp fuse would be OK.
E
Mc7- gamer
Joined May 26, 2016
20
Ohh I get it now
So this
What I will do is be using it to drive 3 Fans with inline fuse
Turn it off and then hook it up to my power supply and hook up resistor in series voltage limit it a 13.5 Volts and Limit it at 600 Milli Amps
Can I use this resistor
https://www.jaycar.com.au/10-ohm-10-watt-wire-wound-resistor/p/RR3352
