How to change gear speed on a multi-planetary gear system based on electricty request?
humptydumptyaac
Joined Nov 3, 2021
36
Thanks everyone.
Irving - regarding your first comment - yes, I meant that I'd use a wider wheel keeping in mind that I'd have control over the water flow.
Yaakov - thanks, I'd seen that design in a documentary I'll look further into it, though for starters just a simple wheel with paddles would do to test things out.
Bob - yes, I have done the calculations and a wider wheel should have more power. I just wanted to check in case there was something I was missing.
BobaMosfet - thanks for the recommendation. I'd gotten a couple of introductory books on electronics. I will be reading them.
