How to calculate voltage (V) between resistors in parallel?
Mannerheim
Joined Oct 16, 2021
4
I have added a picture about a simple circuit. I need to find Voltmeter reading between resistors as shown in picture.
The resistor values are:
R1 = 10
R2 = 90
R3 = 30
R4 = 170
Battery is 20 volts.
Is it possible to simplify the circuit?
DickCappels
Joined Aug 21, 2008
10,661
Probably not. You just have a 20 volt source and two voltage dividers. Just calculate the voltage across resistor in each divider, say the right side (R2 and R4) and then compare the voltages. It is hard to make it simpler than that.
Mannerheim
Joined Oct 16, 2021
4
Thank you,
to calculate voltage across resistor in each divider - is this the proper way to calculate:
R = (R2 * R4) / (R2 + R4)
R = (R1 * R4) / (R1 + R3)
DickCappels
Joined Aug 21, 2008
10,661
The dividers are horizontal dividers along the top and bottom.
R2 x(20V/(R1+R2)) is the voltage across the right-side resistor on the top, and
R4 x(20V/(R3+R4)) is the voltage across the right-side resistor on the bottom.
So what, then is V?
n0dlb
Joined Oct 16, 2021
3
Hi. Don't overthink this. the 2 pairs of series resistors in parallel are still just basic voltage dividers. There is still 20V across both pairs.
Take series R1 + R2 10 ohm and 90 ohm, 100 ohm total so a 10/90 or 9:1 ratio, however you wanna look at it. So as a voltage divider you'll have 2V across R1 (10% of 20V and 18V on R2). By the same math 3V across R3 and 17V on R4.
Taking it a bit further what is the current in each leg?? not hard either, E=IR is all you need. I'll let YOU figure that out. You can then figure out the equivalent resistance with E=IR after you figure the current out, no need for fancy parallel resistance calculations. Then it's easy as P=IE to figure out the power!
Mannerheim
Joined Oct 16, 2021
4
Thank you for your kind help and suggestions. Basically the curcuit is a voltage divider (https://en.wikipedia.org/wiki/Voltage_divider) that can be divided into two linear voltage dividers.
Vin = U = 20 V
Then the Vout from the first linear voltage divider is:
Vout1 = R2 x (Vin/(R1+R2))
The second:
Vout2 = R4 x (Vin/(R3+R4))
And to get the voltage between the two:
V = abs( Vout1 - Vout2 )
Mannerheim
Joined Oct 16, 2021
4
Because voltage is difference of potentials (Vout1 and Vout2). If Vout1 - Vout2 is a negative number, then the difference is absolute value of that negative number...
35,180
The negative sign is equally important as a positive sign. It has significance.
Don’t throw away the sign.
DickCappels
Joined Aug 21, 2008
10,661
For that to work, the solution needs to be the voltage on point A (for example) with respect to point B (also for example). The use of ABS is consistent with the problem as posed, but yes, it real life, the sign will usually be important.
BobaMosfet
Joined Jul 1, 2009
2,211
R1 = 10
R2 = 90
R3 = 30
R4 = 170
Title: Understanding Basic Electronics, 1st Ed.
Publisher: The American Radio Relay League
ISBN: 0-87259-398-3
35,180
In an audio amplifier repair thread, we asked the TS to measure the voltage at a certain point in the circuit.
The TS failed to inform us that the voltage reading on the DMM was negative.
What a difference that negative sign made to the analysis of the circuit!
