Hello.
I am studying a commercial product of LED DIMMER controlled based on PWM.
The product can dim the LED with the following specifications.
Maximum Spec : 12VDC, 50A, 600W
And as the core device, SM6020NS Mosfet is used. (http://www.sinopowersemi.com/temp/SM6020NSFP_datasheet.pdf)
I have a question here.
Q1. The device can dissipate up to 83W of power at a case temperature of 25 degrees,
But, The device's Rds(on) is 4.5m Ohm.
And, Mosfet power consumption formula I think is as below.
Why does the manufacturer of the product not use a product that can only consume 20W, but use a device that can consume 83W?
Q2. How can you help me with Thermal Resistance-Junction to Case or Thermal Resistance-Junction to Case?
Q3. The picture below is a commercial product that I am currently studying.
I would like to make a product like this myself.
Can you give me a link to find a starting point for me to study?
I = 50A
R = 0.0045 Ohm
W = V * I
V = I * R
V = 0.225V
W = 11.25W
