Hi, anyone knows if exist a specific formula to calcolate self and mutual inductance of a 3-polar cable with a fourth conductor used as shield (for example a 3x95mm2+50c cable)? Thanks.
The cable length is 100 meter. Buy i donn'tWhat length of cable is in question?
The procedure described here should provide a means of determining the voltage drop across the inherent series inductance equivalent in one of the wire strands.:
Place a carbon resistor ... essentially no significant inductance ... in series with one of the cable wire strands. Apply an AC voltage across the two terminal ends of this assembly ... One at the resistor and the other at the extreme end of the cable wire strand. Measure the voltage drop across the resistor and calculate the current through the resistor and wire strand. Use the wire cross sectional area, length, and resistivity to calculate a resistance value for the wire strand. Using this resistance and the previous current calculation, find the voltage drop across the wire resistance. Add the resistor voltage drop to the wire resistance voltage drop. Subtract the sum from the voltage that is applied to the entire unit ... resistor plus wire.
The resulting difference will be the voltage that exists across the inductance existing in the test strand ...
correction ... subtraction of the sum resistance voltage is incorrect ... must use Pythagorean Theorem.
But i don't have the possibility to measure it physically, i have to do an estimation of It. So this Is why i asked if there Is some theoretical expression based on cable geometry.What length of cable is in question?
| Thread starter | Similar threads | Forum | Replies | Date |
| Y | exctracting loop inductance from S-parameters | PCB Layout , EDA & Simulations | 0 | |
| M | Inductance values versus voltage? | Analog & Mixed-Signal Design | 3 |
