How to build a switch that is normally closed and opens, when power is applied
AnalogKid
Joined Aug 1, 2013
12,287
Just a demonstration, you can substitute 550k and 1mF or what ever
This has the same limitation as previous circuits: There is no rapid discharge path for the C2 charge if the cycle is terminated early by removing the 12 V supply. The voltage across C2 never reaches the Threshold trip point, so the Discharge output never comes on.
ak
