Sir, I can manage with programming.Sounds like you may need more help than we can give on this forum.
Do you know anyone that can help you with the electronics?
Who will program the micro?
Compensation factor = Constant÷voltageWhat is the equation for the temperature compensation? If it is simple then you may be able to get from input to output entirely in analogue, if you want 4-20mA output.
If I am able to choose the correct ICs then I believe I can build the circuit.Sounds like you may need more help than we can give on this forum.
