How to build a inverter similar circuit with MOSFETS which involves negative output voltage?
achen
Joined Sep 11, 2022
18
How to build the following circuit?
When input is rising from 0V to 1V, output drop from 0V to -1V.
when input is dropping from 1V to 0V, output rise from -1V to 0V
Papabravo
Joined Feb 24, 2006
21,345
Your description sounds like an inverting operational amplifier. Do you want to build or simulate one using MOSFETs? If so, the building locks would be:
  1. Differential amplifier
  2. Current mirror
  3. Class A gain stage
  4. Level shifter
  5. Output stage
Are you familiar with these circuits? If not, then you should probably research them individually. This might be a good place to start
https://www.allaboutcircuits.com/technical-articles/the-basic-mosfet-differential-pair/
Ian0
Joined Aug 7, 2020
10,293
Is this a signal inverter (an inverting amplifier) or a power inverter (to produce a negative supply from a positive supply)?
