how to assure a flip flop is in the correct position on power up?
shortbus
Joined Sep 30, 2009
10,049
Since my hand injury is keeping me from doing any real manual work, I've started back on my long, long on going project, an electrical discharge machine. So my question is how do you make a CD4013 flip flop always be in the same configuration on power up? I know you chose either the set or reset pin, depending on how the circuit starts but how do you make sure the right one is used at every circuit start up?
shortbus
Joined Sep 30, 2009
10,049
Thank you all for your answers.
I'm very dumb about circuit design. When I posted my first iteration of this circuit way back in the day, there were so many mistakes and I got very discouraged, and went back to things I know how to do machine work and fabricating things. But this project is always on the back burner.
My original design was way too involved and just plain bad. What this is going to be is similar to a R-C oscillator but digital. I know what it's supposed to be doing just not how to make a schematic. I can usually find things but it helps when you know the right question to ask. :) Again thank you guys for the help.
neonstrobe
Joined May 15, 2009
200
I generally use a Schmitt trigger rather than a D-type. You can build one with two or three transistors or an op-amp which works from 5V.
shortbus
Joined Sep 30, 2009
10,049
BTW, this is called a Power-On Reset (POR) circuit.
ak
I found that out after I started the thread. Not being trained or schooled in this stuff is hard on a 75 year old guy. :) By the way, will this power on reset work on both the set and reset? I am assuming it will.
shortbus
Joined Sep 30, 2009
10,049
Hi guys, new question on the same thing. I'm using both flip flops on a single CD4013, can I use only a single cap and resistor for the two of them, or do they each get their own POR circuit?
Papabravo
Joined Feb 24, 2006
22,116
A single circuit should do the job since the inputs are high impedance for all CD4000 series parts.
Papabravo
Joined Feb 24, 2006
22,116
@Papabravo @crutschow Thank you again for the help. This kind of thing isn't shown in any of the flip flop information I've been able to find.
In designs with a microprocessor there are often little circuits called "microprocessor supervisory circuits" which provide a power up reset signal that lasts long enough for the processor oscillator to start beating up and down and stabilize before releasing the RESET or RESET* pin. The MAX809 and MAX810 are parts that I have used. This feature is also quite useful in other types of applications for a small cost in $ and board space.
https://www.onsemi.com/pdf/datasheet/max809s-d.pdf
shortbus
Joined Sep 30, 2009
10,049
Thanks for that, but I'm trying to use the things I have already bought, for my old design. Every thing is using 12VDC and through hole. I'm a dinosaur that doesn't know enough to just die.:)
shortbus
Joined Sep 30, 2009
10,049
Back with another dumb question. Will the POR circuit also work to debounce a push button switch? The switch is NO and will send 12V to start the circuit. All of the switch debounce circuits I found seem to be for a switch going to ground not going "high".
WBahn
Joined Mar 31, 2012
33,366
Yes if the the input is not sensitive to the signal rise-time.
For example, some clock inputs require a minimum rise-time for proper operation.
I've generally seen maximum rise and fall time requirements. The only time I've seen minimums is when the part requires a minimum clock frequency.
