It is the throwing of ideas that is your problem. You are wasting enormous amounts of time and energy to answer quest that have already been considered. To top it off you have no idea where you want to go with this and are just stringing folks along. I call BS on this entire thread.Would it act like a mechanical switch? And put a high power resistor in series to get the voltage.. or put it in common terminal. I'm just throwing ideas.
I will mention it again. For experiment purposes. I will be adding sensors in the coil including different types of materoals to see if any decay or environmental changesWe are free to make assumptions if the TS apparently is not going to tell us. Without knowing the objective of this exercise, given the TS's lack of experience we are just wasting out time (as AGA indicated.)
More importantly, how will you achieve it safely and legally? Given your clear lack of experience, members here might well be be concerned about giving advice. This is not a project you can knock up on a breadboard. 600V can KILL you, and your chosen frequencies are in the MW/SW radio broadcast bands so will be detectable as illegal transmissions.How do I achieve 600v into my coil ?
Thanks for the advice. I have 5000v protection gloves and a Faraday cage the coil will be sitting inMore importantly, how will you achieve it safely and legally? Given your clear lack of experience, members here might well be be concerned about giving advice. This is not a project you can knock up on a breadboard. 600V can KILL you, and your chosen frequencies are in the MW/SW radio broadcast bands so will be detectable as illegal transmissions.
How would you apply that transistor to the coil?How much magnetic field are you trying to create?
600V into 18mH at 3MHz is still only 5mA.
Also, don't forget that if you start with a 600V supply, then you will end up with 1200V on the switching device.
A TV horizontal output transistor or valve might be the answer.
I best start with smaller current and increase voltage if I need. But square wave is a must. The counter inductance magnetic field will go the opposite direction affecting the impulse wave so making a fast rise square wave will be hardThat depends on whether I need a sinewave or whether I thought I could get away with a squarewave (with a triangular current waveform), and whether 5mA was really enough current.
@sparky 1 It is some difference between your and my simulations (4700mA vs 1.5mA).63 mH 4700mA
Multi level ? first a CS amplifier for voltage amplification then a common drain for current amp ? i was initially thinking of a tank circuit, but if there is a way of automatically changing the capacitance I can add this to the program.I imagined it with a power semiconductor (probably a SiC MOSFET) with the coil as its drain load, with all the associated problems with drain-source capacitance etc.
by Jake Hertz
by Duane Benson
by Duane Benson
