How to adjust the amplitude of the square wave?
circuitnaiver
Joined Oct 1, 2021
22
Hello, guys,
I have a circuit design to output the +6V and -12V square wave with the input 0V and 6V. Vout is connected to the oscliscope.
One of my friends designed this circuit. But it does not work in the simulation. Can anyone help me out with this?
Thank you~
38,844
Are you constrained to 6V and -12V supplies or can they be higher voltages?
What should be the output voltage for 0V input?
38,844
But the ideal case is that we only single supply, like 6V directly from the input source without any added power supply.
That's not ideal, that's impossible.
How do you expect to get -12V from a +6V supply.
An opamp can only output no more that its supply voltages.
If this is school work, why are you using someone else's design?
Shouldn't you be doing your own?
I have a design that does what you want using only 4 resistors and the opamp, but you need to demonstrate some understanding of op amps circuits before I will post that.
circuitnaiver
Joined Oct 1, 2021
22
I think I understand how it works. The Op amp can work as a comparator by comparing one analog voltage level with another analog voltage level. Something work as follows:
dcbingaman
Joined Jun 30, 2021
1,065
Hello, guys,
Thank you~
You can accomplish the goal also with 2 BJT transistors and a few resistors. Because this is homework, can't provide solution but something to think about.
