What ac to dc switch would be needed to activate an MP3 Trigger?
The MP3 trigger plays audio tracts. It has a trigger sensor (3.3-5.0vdc) that triggers audio tracts to play.
When I turn on a switched outlet (120vac), i would like the ac to dc switch to send a signal to the MP3 Trigger.
I will also have an LED light box (I believe its 10 or 20 watts) connected to this switched outlet.
The MP3 Trigger is found below.
Thank you Members
Pylass
https://www.sparkfun.com/products/13720
Thank you Members
Pylass
